Product Functions: Single/multipoint temperature detection under electrified state, temperature measurement; temperature compensation for strain and stress sensors.
This is a companion discussion topic for the original entry at https://www.ofscn.net/fbg-products/fbgs-insulated
This topic discusses the OFSCN® Ceramic-encapsulated Fiber Bragg Grating Temperature Sensor, which is specifically designed for high-voltage environments or applications requiring electrical insulation.
Technical Overview
Based on the technical specifications for this product line, here are the core characteristics:
- Insulation Feature: It uses a ceramic tube packaging (which can be reinforced with a seamless steel tube nest) to provide insulation properties under specific voltage conditions.
- Temperature Range: The measurement range is highly customizable, covering from -270°C to 800°C.
- Dimensions: The default outer diameter is 2.0 mm, with a 3.0 mm option available upon request.
- Sensing Capability: It can be manufactured as either a single-point sensor or a multi-point FBG sensor string.
Product Visuals
Below are the standard images for the ceramic-encapsulated series:
Detailed Specifications
For full technical parameters, calibration formulas, and customization options, please refer to the official product page:
If you have specific requirements regarding the insulation voltage levels or the required temperature gradient for your project, please feel free to provide those details for further technical evaluation.
