Thank you for sharing the functional overview of the OFSCN® Low-Voltage Insulated FBG Temperature Sensor.
As a supplement to the technical description, it is important to note that this series is specifically designed for environments where electrical isolation is required alongside precise thermal monitoring. By utilizing the inherent non-conductive properties of optical fibers combined with specialized insulation packaging, these sensors effectively eliminate electromagnetic interference (EMI) issues common in power distribution or electrified industrial equipment.
Key Technical Characteristics
Based on the technical standards of the OFSCN® FBG Temperature Sensor (Low Voltage Insulation), here are the core advantages:
Multi-Point Multiplexing: As mentioned, a single fiber string can integrate multiple FBG sensing points, allowing for a comprehensive temperature profile along a single cable run.
Safety & Isolation: The use of high-dielectric materials ensures safety during temperature detection in low-voltage electrified environments.
High Accuracy: It maintains the high resolution and stability characteristic of Fiber Bragg Grating technology, unaffected by high-voltage sparks or magnetic fields.
Product Visuals and Details
For more detailed technical specifications and physical dimensions, you may refer to the official documentation:
If you are evaluating this sensor for a specific project, please feel free to provide the operating temperature range or the installation environment details so we can discuss the optimal configuration.
