What drastic changes occur in mechanical properties once a coating material exceeds its Tg?
When a coating material exceeds its Glass Transition Temperature (Tg), it undergoes a significant change in its mechanical properties. Below Tg, the material is in a glassy state, characterized by being hard, stiff, and brittle. Above Tg, it transitions to a more rubbery or viscous state.
The drastic changes include:
- Reduced Stiffness and Modulus: The material becomes much softer and less rigid. Its Young’s modulus significantly decreases.
- Increased Flexibility and Ductility: It becomes more pliable and able to deform without fracturing.
- Increased Viscoelasticity: The material exhibits more pronounced time-dependent deformation, meaning it will deform over time under a constant load (creep) and will not fully recover its original shape immediately after the load is removed.
- Loss of Dimensional Stability: The material may become less dimensionally stable and more susceptible to flow or permanent deformation under stress, especially at higher temperatures above Tg.
For fiber optic sensors, especially Fiber Bragg Grating (FBG) strain sensors, operating above the coating’s Tg can lead to issues such as:
- Creep in Strain Measurements: The coating can creep under sustained strain, leading to drift or inaccuracies in the measured strain.
- Degradation of Sensor Performance: The structural integrity of the sensor might be compromised if the coating fails to protect the bare fiber or adequately transfer strain.
To address high-temperature applications, OFSCN® utilizes specialized fiber coatings designed for extended temperature ranges. For instance:
- Standard polyacrylate coatings, typically used in OFSCN® G.652D Optical Fiber and OFSCN® G.657 Optical Fiber, are suitable for temperatures up to around 100°C.
- For higher temperatures, polyimide coatings, as found in OFSCN® 300 SM Polyimide Optical Fiber or OFSCN® 200 Polyimide Optical Fiber, can extend the operating range to 200°C or 300°C, and even up to 800°C for bare FBGs with special processing.
- For extreme temperature environments, gold-coated fibers, such as OFSCN® Gold-coated Optical Fiber, can withstand temperatures up to 700°C.
Here is an image illustrating optical fibers:
You can explore more details on our website for different fiber types and their specifications.
