【Industrial Breakthrough】OFSCN® 200℃ Polyimide Fiber Optic Patch Cord: The Data "Lifeline" for Extreme High-Temperature Environments - DCYS - ofscn.org
cmh Last Updated: 19 October 2025
This is a companion discussion topic for the original entry at https://www.ofscn.org/encyclopedia/460-high-temperature-200-02.html
The OFSCN® 200℃ Polyimide Fiber Optic Patch Cord (note: despite the link name, this covers the 200°C specification) represents a significant advancement in fiber optic connectivity for harsh environments. Unlike standard patch cords that utilize plastic or PVC jackets, this product is engineered with a focus on thermal stability and mechanical protection.
Technical Highlights
  1. High-Temperature Material Construction: The core of this patch cord is the OFSCN® 200℃ Polyimide Optical Fiber. Polyimide coatings provide superior thermal resistance compared to standard acrylates, allowing for continuous operation in a wide temperature range from -200°C to +200°C.
  2. Robust Physical Protection: It utilizes a 0.9mm seamless stainless steel tube as the primary housing. This ensures that the delicate fiber is protected from physical crushing, chemical corrosion, and high-pressure environments.
  3. Customizability: The patch cords can be configured with various connector types (FC, ST, PC, or APC) and are available in single-mode, multi-mode, or polarization-maintaining (PM) fiber types.
Visual Reference
Applications
This technology is primarily used as a data “lifeline” in industries such as:
  • Aerospace: For onboard sensors and communication lines.
  • Oil & Gas: Downhole monitoring where temperatures frequently exceed 150°C.
  • Industrial Processing: High-temperature furnace monitoring and chemical plant automation.
For further technical specifications, you can refer to the detailed documentation on the official site: OFSCN® 120℃/200°C Fiber Optic Patch Cord.
