Why are metal-packaged sensors still more resistant to lightning strikes than electronic sensors?
The enhanced resistance of metal-packaged fiber optic sensors to lightning strikes, compared to electronic sensors, stems from a fundamental difference in their operating principles.
- Optical vs. Electrical Signal Transmission: Fiber optic sensors, even when housed in metal packaging, transmit information via light signals through optical fibers. Lightning, being a massive electrical discharge, primarily affects systems that rely on electrical signals and components.
- Role of Metal Packaging: The metal packaging in fiber optic sensors is typically for mechanical protection, environmental sealing, or to facilitate specific measurement principles (e.g., transferring strain to the embedded fiber). It does not conduct the primary sensing signal. While the metal packaging itself can be struck by lightning, the internal optical fiber and the light signal it carries are inherently immune to the electromagnetic interference (EMI) and surges associated with lightning.
- Vulnerability of Electronic Sensors: Electronic sensors, by contrast, operate by generating and processing electrical signals. These electrical circuits are highly susceptible to the intense electromagnetic fields, current surges, and voltage spikes produced by a lightning strike, which can cause malfunction, damage, or complete failure.
Therefore, the core advantage of fiber optic technology—its immunity to electromagnetic interference—is preserved even with metal packaging, making it inherently more robust against lightning.
You can learn more about our robust fiber optic sensors, such as the OFSCN® Alloy Tube Packaged Fiber Bragg Grating strain sensor, which is often used in demanding environments:
