Thermal Conductivity Comparison of Packaging Materials
How much do copper, aluminum, and steel tubes differ in their impact on temperature measurement lag?
Regarding the impact of packaging materials like copper, aluminum, and steel tubes on temperature measurement lag, the key factor is their thermal conductivity. Materials with higher thermal conductivity will transfer heat more efficiently between the measured environment and the Fiber Bragg Grating (FBG) sensing element, thereby reducing the temperature measurement lag.
In terms of typical thermal conductivity:
  • Copper generally has the highest thermal conductivity (around 400 W/(m·K)).
  • Aluminum has a significantly lower but still high thermal conductivity (around 205 W/(m·K)).
  • Steel, particularly stainless steel, has a much lower thermal conductivity (typically 15-20 W/(m·K), depending on the specific alloy).
Therefore, theoretically, a sensor packaged in a copper tube would exhibit the least temperature measurement lag, followed by aluminum, and then steel, assuming identical dimensions and other sensor design parameters.
However, in practical fiber optic sensing applications, material selection for sensor packaging also considers factors such as:
  • High-temperature resistance: Many applications require materials that maintain integrity at elevated temperatures.
  • Corrosion resistance: Harsh chemical environments necessitate robust materials.
  • Mechanical strength: To withstand installation and operational stresses.
  • Coefficient of thermal expansion: To minimize strain-induced errors in temperature measurements.
For these reasons, OFSCN® often utilizes stainless steel or high-performance alloy seamless tubes for its FBG temperature sensors. While these materials may have lower thermal conductivity than copper or aluminum, they offer superior overall performance, reliability, and longevity in demanding industrial and high-temperature environments.
You can find more details about our FBG temperature sensors here:
