Where are these ultra-thin cables typically used? Are they extremely fragile?
These ultra-thin cables, specifically the 0.9mm buffered fibers or micro-patch cords, are typically used in environments where space is extremely limited or where specialized sensing and connectivity are required.
1. Typical Applications
- High-Density Equipment Rooms: They are used in dense distribution frames or inside compact optical devices where standard 2.0mm or 3.0mm cables would be too bulky.
- Harsh & High-Temperature Environments: When used as micro-patch cords, they often feature specialized coatings (like Polyimide or Metal) for sensing or signal transmission in extreme conditions (e.g., inside engines, ovens, or industrial pipes).
- Sensor Integration: 0.9mm is the standard diameter for many buffered FBGs (Fiber Bragg Gratings) and is often integrated into larger mechanical structures for strain or temperature monitoring.
2. Are they fragile?
Fragility depends entirely on the internal structure of the 0.9mm cable. At OFSCN®, we offer two distinct types with very different mechanical properties:
- Standard Buffered Fiber (Non-Armored): These consist of the optical fiber with a tight buffer (PVC/LSZH). They are relatively fragile and sensitive to lateral pressure and sharp bends. These are generally used for internal routing where they are protected by an outer enclosure.
- OFSCN® Micro Steel Armored Patch Cords (0.9mm): To solve the fragility issue, we utilize 0.9mm seamless stainless steel tubes as the protective layer. This design makes the cable significantly more robust than traditional plastic-buffered fibers.
For instance, our OFSCN® 300°C Fiber Optic Patch Cord uses a 0.9mm stainless steel tube. It provides high crush resistance while maintaining the ultra-thin profile, making it suitable for industrial deployment rather than just laboratory use.
Standard Product Image (0.9mm Armored Type):
Recommended Products:
- OFSCN® Standard Fiber Patch Cord (Customizable to 0.9mm)
- OFSCN® 120°C Fiber Optic Patch Cord (0.9mm Stainless Steel Tube)
- OFSCN® 300°C Fiber Optic Patch Cord (0.9mm Stainless Steel Tube)
If you are planning to use these in a specific engineering environment, could you specify the maximum operating temperature and whether they will be subject to mechanical stress? This will help determine if you need the armored stainless steel version or a standard buffer.
