In non-metallic packaging, should 502 glue or epoxy resin be used? What is the temperature resistance difference?
In the non-metallic packaging, fixation, or surface mounting engineering of fiber optic sensors (such as Fiber Bragg Gratings, FBGs), the use of 502 super glue in the formal packaging structure is strongly discouraged, and engineering-grade two-component epoxy resin (Epoxy) should typically be chosen.
There are fundamental differences in their chemical structures, temperature resistance, and mechanical stability, analyzed as follows:
I. Comparison of Temperature Resistance: What’s the Difference?
| Indicator / Property | 502 Super Glue (Ethyl \alpha-cyanoacrylate) | General/High-Temperature Epoxy Resin (Epoxy) |
| Long-Term Operating Temperature Limit | Approx. 70^\circ\text{C} \sim 80^\circ\text{C} | General Type: Approx. 100^\circ\text{C} \sim 120^\circ\text{C} High-Temperature Grade/Fiber Optic Specific (e.g., 353ND): Can reach 150^\circ\text{C} \sim 200^\circ\text{C} |
| Extreme/Short-Term Temperature Resistance | Rapid softening and degradation above 80^\circ\text{C} | Some high-temperature formulations can withstand 250^\circ\text{C} \sim 300^\circ\text{C} for short periods |
| Low-Temperature Performance | Extremely brittle at low temperatures (< 0^\circ\text{C}), poor impact resistance | High-quality formulations can withstand -40^\circ\text{C} or even cryogenic temperatures (-196^\circ\text{C}) |
| Temperature Difference | The difference in upper temperature limits is typically over 50^\circ\text{C} to 130^\circ\text{C} | — |
- 502 Super Glue: Based on single-component moisture-catalyzed polymerization, its polymer molecular chains are relatively linear-elastic with a low thermal degradation temperature. When the ambient temperature reaches above 70^\circ\text{C}, the adhesive layer begins to soften, molecular chains degrade, and adhesive strength drops sharply, leading to irreversible aging and failure.
- Epoxy Resin: Forms a three-dimensional, highly cross-linked network macromolecular structure through the reaction between the main agent and the curing agent, possessing a high glass transition temperature (T_g). With a proper thermal curing process, the cross-linked network can maintain stable elastic modulus and shear strength even above 150^\circ\text{C}.
II. Key Differences in Packaging and Sensing Mechanisms
Beyond temperature resistance, the core reasons for excluding 502 super glue and choosing epoxy resin in optical packaging also include:
- Creep Characteristics and Strain Transfer
- 502 Super Glue: Under long-term stress or fluctuations in ambient temperature and humidity, it is prone to significant molecular slippage and creep, leading to hysteresis in stress/strain transfer to the Fiber Bragg Grating and drift in the measurement zero point.
- Epoxy Resin: After curing, it forms a dense cross-linked structure with a moderate elastic modulus and excellent creep resistance, ensuring shear stress is elastically transferred from the outer casing or substrate to the fiber core.
- Residual Internal Stress and Spectral Distortion
- 502 Super Glue: Cures extremely rapidly (seconds to tens of seconds), with intense exothermic reactions and uneven volumetric shrinkage during curing. This easily induces non-axisymmetric lateral residual stress in the fiber cladding, causing fiber birefringence and leading to spectral broadening or splitting (double peaks) of the grating reflection spectrum.
- Epoxy Resin: Curing time is controllable (supports gradual cross-linking with stepped heating), allowing for uniform release of internal stress, which is more conducive to preserving the integrity of the fiber’s optical characteristic spectrum.
- Moisture, Heat Resistance, and Aging Stability
- 502 super glue has very poor resistance to moisture and aging. It easily powders, hydrolyzes, and debonds in humid environments. High molecular epoxy systems exhibit good resistance to acids, alkalis, humidity, and hydrolysis.
III. Industrial-Grade Packaging Explanation
502 super glue is only suitable for temporary fixation or pre-positioning in laboratory environments at room temperature and should never be used as the primary adhesive for non-metallic sensor packaging.
It should be noted that various general-purpose commercial adhesives (including 502 super glue and commercially available general epoxy resins) are not part of the core product line of Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®). In practical engineering, if the measurement environment involves higher temperature zones (e.g., 150^\circ\text{C} \sim 300^\circ\text{C} or higher) or has stringent requirements for long-term fatigue resistance and zero creep, non-metallic polymer packaging often presents inherent material aging and temperature resistance bottlenecks. Therefore, fully metallic (seamless steel pipe, elastic alloy pipe) packaging structures are usually recommended.
