Why do pits cause light scattering, leading to a significant signal drop?
A “pit defect” (End-face Pit) on a fiber optic connector or fiber end-face refers to a microscopic concave hole formed on the end-face (especially within or near the core region) during grinding, polishing, end-face cutting, or due to contamination and collision.
From an optical principles perspective, the core mechanism by which pits cause light scattering and lead to significant signal loss (drastic increase in insertion loss, worsening return loss) can be attributed to the following physical processes:
1. Abrupt Change in Refractive Index and Geometric Boundary Disruption
The transmission of light waves within single-mode fiber relies on the total internal reflection constraint formed by the slight refractive index difference between the core and cladding. The effective refractive index of the silica core is approximately n_{\text{core}} \approx 1.45 \sim 1.47.
- When a pit forms on a flat fiber end-face, the pit is typically filled with air (refractive index n_{\text{air}} \approx 1.0).
- The originally flat and uniform exit surface boundary condition of the fiber is disrupted, forming an irregular microscopic curved surface transitioning from a high-refractive-index medium to a low-refractive-index medium at the sub-micron to micron scale.
2. Wavefront Distortion and Diffuse Scattering
According to Huygens-Fresnel principle and wave optics theory:
- Under normal conditions, the exiting light wavefront of the single-mode fiber’s fundamental mode (\text{LP}_{01} mode) maintains high flatness and a Gaussian distribution.
- When the light beam encounters a pit with uneven inner walls, the varying angles at the pit’s edges and bottom cause the refracted and reflected light rays to diverge randomly, according to Snell’s Law.
- This microscopic irregular structure causes severe diffuse scattering of the light beam, which was originally propagating axially along the fiber. The light energy is largely spread into the solid angle of space, leading to an instantaneous collapse of the coherence and energy density of the direct, directional light wave.
3. Mode Field Mismatch and Coupling Loss
When two fiber connectors are physically mated via an adapter (Physical Contact, PC/APC):
- The Mode Field Diameter (MFD) of a single-mode fiber is only approximately 9\ \mu\text{m} \sim 10.4\ \mu\text{m} in communication wavelengths (e.g., 1550\text{ nm}).
- The receiving fiber core only allows light that meets strict spatial phase and field distribution matching to be coupled into the fundamental mode. The scattering caused by pits leads to a sharp increase in the beam divergence angle and wavefront distortion.
- The scattered light cannot satisfy the numerical aperture (NA) and waveguide boundary conditions of the receiving fiber core. The vast majority of scattered light spills out of the core, enters the cladding where it is absorbed and dissipated as cladding modes, or leaks directly at the interface. This results in a significant attenuation of transmitted optical power (leading to extremely high insertion loss, IL).
4. Fresnel Reflection and Interference Loss Caused by Air Gaps
Physical mating of end-faces originally requires them to be in close contact to eliminate air gaps. Pit defects can lead to local air gaps in the connector interface micro-region:
- The glass-air interface, due to the refractive index mismatch (n \approx 1.468 \to 1.0 \to 1.468), causes approximately 4\% (about -14\text{ dB} for a single interface) Fresnel Reflection.
- Multiple reflections within the air gap can also create a micro-Fabry-Pérot (F-P) interference cavity effect, causing wavelength-sensitive oscillations. This not only directly reduces forward transmission power but also causes reflected light to return to the demodulator/laser source, leading to worsening optical return loss (RL) or even increased laser noise.
Summary
In fiber sensing and fiber communication systems (such as Fiber Bragg Grating (FBG) sensing systems), optical energy is concentrated within a very narrow, micron-scale core region. Therefore, pits located within the core zone (Zone A), even if their size is only 1\ \mu\text{m} \sim 2\ \mu\text{m}, will directly disrupt the fundamental mode’s core transmission path, inducing strong diffuse scattering and mode field mismatch. This is the physical root cause for the strict “zero tolerance” criterion for pits and scratches in the core region stipulated by international end-face inspection standards (e.g., IEC 61300-3-35).
