What is "domestic encapsulation technology"?
Why is OFSCN®'s seamless steel pipe process a core competency?
From the perspective of optical engineering and sensor physical packaging, OFSCN®(OFSCN®)takes seamless stainless steel micro-tube packaging technology (including single-layer, double-layer, and multi-layer nested seamless tube processes) as its core competency, primarily based on the following physical principles and engineering advantages:
1. Complete Elimination of Weld Defects, Providing Uniform Compressive and Hermetic Protection
  • Weld-Free Weak Zones: Traditional welded tubes are prone to issues such as uneven longitudinal welds, micro-cracks, or residual stress concentrations, especially in micro-diameters. Seamless steel tubes offer isotropic and uniform wall thickness and grain structure in the circumferential direction, significantly enhancing resistance to hoop stress and burst pressure.
  • Full Metal Hermetic Barrier: Seamless steel tubes provide a completely sealed physical barrier for the internal optical fiber, effectively isolating external moisture, corrosive media (such as acidic/alkaline solutions, H₂S), and hydrogen molecules at high temperatures. This completely prevents fiber core absorption loss (hydrogen aging) caused by hydrogen diffusion, ensuring the transmission performance and signal-to-noise ratio of the sensing signal throughout the fiber’s long lifespan.
2. Extreme Temperature Adaptability and Material Thermal Matching
  • Wide Temperature Range Coverage (-270°C to +800°C): Polymer materials undergo thermal degradation, carbonization, or volatilization at ultra-high temperatures and become brittle at extremely low temperatures. Seamless steel tubes, made from materials like 304, 316L stainless steel, or Inconel 825 alloy, coupled with high-temperature resistant optical fibers (such as polyimide-coated or gold-coated fibers), can operate stably for extended periods in environments ranging from cryogenic temperatures (like liquid nitrogen/helium) to extreme heat.
  • High Thermal Conductivity and Fast Thermal Response: Metallic materials possess good thermal conductivity. Miniature, thin-walled seamless steel tubes (with inner diameters as small as 0.5 mm to 0.9 mm and wall thicknesses of only 0.1 mm to 0.3 mm) significantly reduce the thermal mass of the packaged structure, enabling the sensor to have an extremely fast thermal response speed.
3. Decoupling of Temperature and Strain in Physical Space (for Temperature Sensing)
  • In Fiber Bragg Gratings (FBGs) and Distributed Temperature Sensors (DTS/OFDR), if adhesives or structural constraints are used, strain generated by substrate deformation will be coupled with temperature effects.
  • OFSCN®'s seamless steel tube packaging technology allows the optical fiber/grating to be placed in a free-floating state (loose tube packaging) within the micro seamless tube cavity. This completely isolates external mechanical tensile, bending, and compressive strains, eliminating cross-sensitivity and ensuring that the measured Bragg wavelength shift strictly corresponds to the ambient temperature change (ΔλB ∝ ΔT).
4. Miniaturization and Multi-Layer Nesting Engineering Capabilities
  • OFSCN® has mastered the high-precision process of inserting and packaging delicate optical fibers (cladding diameter 125 µm) into micro-inner-diameter seamless metal tubes. This enables the creation of miniature sensors with outer diameters of 0.5 mm and 0.9 mm, as well as nested double-layer downhole optical cables with outer diameters of 2.0 mm, 3.0 mm, or one-quarter inch (approx. 6.35 mm). This achieves an excellent balance between extremely small geometric dimensions (reducing structural invasiveness) and high mechanical strength (tensile, compressive, and rodent resistance).
Representative Products and Official Specifications
1. Fiber Bragg Grating (FBG) Temperature Sensor Series
Utilizing single or multi-layer seamless steel tube packaging, with temperature measurement covering from room temperature to 800°C:
2. Seamless Steel Tube Optical Cables and Distributed Fiber Sensor Series
Encased in 304/316L/825 alloy seamless steel tubes, suitable for specialized communications and distributed sensing (Raman DTS / OFDR / Brillouin BOTDA):
