What is "polishing pressure" control?
When the pressure is too high, it will wear out, and when the pressure is too low, it will not flatten. How do manufacturers control this?
In the end-face processing of fiber optic connectors (such as FC/PC, FC/APC, SC, LC, etc.), Polishing Pressure control refers to the precise management of the normal force exerted by the polishing machine’s fixture onto the ferrule, acting through the Polishing Film and Rubber Pad during the grinding process.
The grinding process follows the classic Preston’s equation:
\Delta h = k \cdot P \cdot V \cdot \Delta t
Where \Delta h is the material removal depth, k is the wear coefficient (related to polishing particle material and lubricating medium), P is the contact pressure (polishing pressure), V is the relative linear velocity between the polishing disk and the ferrule end-face, and \Delta t is the polishing time. Therefore, the polishing pressure directly determines the Material Removal Rate (MRR) and the topography profile of zirconia ceramic and silica fiber.
I. Physical Failures Caused by Pressure Imbalance
The polishing process window is extremely stringent, and pressure imbalance can lead to the following typical failures:
  • Excessive Pressure:
    • Subsurface Damage and Micro-cracks:
      High shear stress can cause brittle fracture or invisible micro-cracks in the quartz core, worsening insertion loss and polarization characteristics.
    • Deep Scratches and Fiber Undercut:
      Quartz glass has a lower hardness than the ceramic ferrule. Under excessive pressure, the polishing grains abrade the fiber core at a significantly faster rate than the ceramic substrate, leading to severe depression on the fiber end-face. This creates an air gap during fiber mating, severely degrading return loss.
    • Radius of Curvature (RoC) Too Small:
      The polishing pad is excessively compressed, causing the end-face curvature to become too steep, exceeding IEC / Telcordia international standards (e.g., PC requires 10\ \text{mm} \le R \le 25\ \text{mm}).
  • Insufficient Pressure:
    • Inadequate Material Removal and Residual Epoxy:
      Epoxy squeezed out during pre-assembly is not completely removed, and deep scratches left by coarser abrasive particles in previous steps are not smoothed out in the subsequent fine polishing stages.
    • Excessive Fiber Protrusion:
      Due to insufficient abrasion of the ceramic substrate, the fiber core protrudes excessively, leading to chipping upon impact during mating.
    • Exceeding Apex Offset:
      Uneven force distribution and insufficient pressure can cause the highest point of the spherical surface to deviate from the geometric center of the fiber core, resulting in poor physical contact.
II. How Manufacturers Precisely Control Polishing Pressure in Production?
Industrial-grade fiber end-face polishing equipment and processes typically employ the following multi-dimensional synergistic solutions to stabilize pressure:
1. Mechanical End: Independent Spring-Loaded Fixture per Ferrule
  • Industrial polishing fixtures usually hold 12 to 48 ferrules at a time. Due to micron-level mechanical tolerances in the assembly height of each ferrule, a rigid pressure plate would cause the tallest ferrule to bear all the pressure, leaving shorter ferrules unsupported.
  • Solution: Each holding hole within the fixture is equipped with a precision calibrated spring. When the main spindle is pressed down to a fixed mechanical stroke, each ferrule is pressed independently by its own spring. This ensures uniform pressure applied to each ferrule (typical single-head pressure ranges from 1.5\ \text{N} \sim 4.5\ \text{N}, with an accuracy of \pm 0.1\ \text{N}).
2. Equipment End: Pneumatic Proportional Valve / Servo Closed-Loop Pressurization
  • Modern high-precision fiber polishers generally abandon purely manual pressurization in favor of high-precision electro-pneumatic proportional valves or servo motors coupled with micro load cells.
  • The control system adjusts the total air pressure applied to the main spindle in real-time according to the process setpoints, eliminating the influence of air pressure fluctuations on the applied force and achieving millisecond-level closed-loop feedback control.
3. Medium End: Matching Hardness and Thickness of Elastic Polishing Pads
  • The polishing pad material is typically fluoroelastomer or silicone rubber. Its Shore A Hardness (commonly between 60^\circ \sim 80^\circ) directly modulates the local contact stress distribution.
  • Higher hardness pads resist deformation better, which helps reduce polishing defects; lower hardness pads create a larger elastic wrap-around indentation, used to control the radius of curvature of the final product.
4. Process End: Multi-stage Process Recipe with Stepwise Pressure Control
Polishing typically consists of 3 to 5 steps (epoxy removal \rightarrow rough grinding and shaping \rightarrow fine grinding and finishing \rightarrow polishing):
  • Epoxy Removal and Shaping Stage (e.g., using 16\ \mu\text{m} \sim 9\ \mu\text{m} Silicon Carbide or Diamond polishing films): Apply medium/high polishing pressure to quickly level excess fiber protrusions and epoxy resin, forming a basic spherical profile.
  • Finishing and Smoothing Stage (e.g., using 3\ \mu\text{m} \sim 1\ \mu\text{m} Diamond polishing films): Apply stable medium polishing pressure to control the cutting depth and eliminate scratches from the previous stage.
  • Final Polishing Stage (e.g., using 0.02\ \mu\text{m} Silica/Cerium Oxide polishing films): Employ low polishing pressure combined with Chemical Mechanical Polishing (CMP) to repair microscopic lattice defects on the end-face, ensuring the fiber core is flush with the ferrule (flatness within \pm 50\ \text{nm} tolerance) and free of scratches.
Note: Fiber end-face polishing machines, fixtures, and consumables are common tooling and assembly equipment for fiber optic connector processing and manufacturing, and do not belong to the core product line of Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®).
