What is the "attenuation coefficient"?
Why is the loss per kilometer smaller at 1550nm than at 1310nm?
In standard silica single-mode fibers, attenuation coefficients (unit: \text{dB/km}) exhibit significant differences at typical wavelengths: attenuation at 1310\text{ nm} is usually around 0.35\text{ dB/km}, while at 1550\text{ nm} it drops to approximately 0.18 \sim 0.20\text{ dB/km}.
This physical phenomenon is primarily determined by the wavelength-dependent characteristics of the intrinsic loss mechanisms in silica glass (\text{SiO}_2)—Rayleigh Scattering and Infrared Absorption.
1. Wavelength Fourth-Power Law of Rayleigh Scattering (Dominant Factor)
During the high-temperature molten drawing and rapid cooling of silica fibers, the thermal motion of silica molecules is frozen, leading to unavoidable microscopic disorder fluctuations in density and refractive index at a microscopic scale. These microscopic defects, with sizes much smaller than the wavelength of light, induce Rayleigh scattering.
The Rayleigh scattering loss coefficient, \alpha_R, is inversely proportional to the fourth power of the working wavelength, \lambda:
\alpha_R \propto \frac{1}{\lambda^4}
Calculating the change in Rayleigh scattering intensity when the wavelength increases from 1310\text{ nm} to 1550\text{ nm}:
\left( \frac{1310}{1550} \right)^4 \approx 0.51
  • At 1310\text{ nm}, Rayleigh scattering contributes the majority of the attenuation, with a loss of about 0.30 \sim 0.32\text{ dB/km}.
  • At 1550\text{ nm}, due to the longer wavelength, Rayleigh scattering loss drops sharply by approximately 50\%, contributing only about 0.15 \sim 0.16\text{ dB/km} to the attenuation.
This is the most critical physical reason for the significantly lower loss per kilometer at 1550\text{ nm} compared to 1310\text{ nm}.
2. Intrinsic Infrared Absorption Is Not Yet Dominant
The lower limit of fiber attenuation is determined by the molecular lattice resonance absorption of silica:
  • Intrinsic ultraviolet absorption (electronic transitions) decays exponentially with increasing wavelength and is nearly negligible at both 1310\text{ nm} and 1550\text{ nm}.
  • Intrinsic infrared absorption ( \text{Si}-\text{O} bond vibrational resonance, with peak absorption around 9 \sim 10\ \mu\text{m}) has an exponentially increasing tail (Urbach tail) with increasing wavelength.
  • At 1550\text{ nm}, the loss due to infrared absorption is very weak (only about 0.02 \sim 0.03\text{ dB/km}) and does not yet exert a dominant influence on the total loss. Only when the wavelength exceeds 1625\text{ nm} or even 1650\text{ nm} does infrared absorption begin to rise sharply.
3. Combined Physical Effects: The Lowest Loss Window (C-Band)
When the “Rayleigh scattering curve, which rapidly decreases with increasing wavelength” is superimposed with the “infrared absorption curve, which rapidly increases with increasing wavelength,” their intersection point, representing the minimum value, happens to be around 1550\text{ nm}. This forms the theoretical lowest loss window for silica fibers across the electromagnetic spectrum.
Comparing the two wavelength windows:
  • 1310\text{ nm} Window: Located within the zero dispersion wavelength region of standard single-mode fibers (very low dispersion), but constrained by relatively strong Rayleigh scattering, resulting in higher loss (approx. 0.35\text{ dB/km}).
  • 1550\text{ nm} Window: Rayleigh scattering is significantly attenuated, and it has not yet entered the region of strong infrared absorption, thus achieving the globally lowest loss per kilometer (approx. 0.20\text{ dB/km}).
4. Manifestation in Engineering and Products
In practical fiber sensing and industrial communications, standard communication-grade single-mode fibers are designed precisely based on these physical characteristics. For example, the international standard OFSCN® G.652D Optical Fiber, when deployed for long distances, typically prioritizes operation in the 1550\text{ nm} wavelength region to ensure the signal-to-noise ratio of sensors like Fiber Bragg Gratings (FBGs) during long-haul transmission.
