What is the "Effective Refractive Index"?
Why does light travel at a different speed inside an optical fiber compared to the air? Is this index affected by the environment?
The variation in the speed of light within an optical fiber is a fundamental physical phenomenon governed by the properties of the material and the structure of the fiber. Here is a technical explanation regarding the Effective Refractive Index (n_{eff}):
1. Why light speed changes inside an optical fiber
Light travels at its maximum speed (c) in a vacuum. When light enters a medium like the silica glass of an optical fiber, it interacts with the atoms and electrons of the material. This interaction causes a delay in propagation, effectively slowing down the light.
The Refractive Index (n) of a material is the ratio of the speed of light in a vacuum (c) to the speed of light in that medium (v):
n = c / v
In an optical fiber, we use the term Effective Refractive Index (n_{eff}) because light is not traveling through a uniform block of glass. Instead, it is guided within a structure consisting of a core and a cladding. The light exists as an electromagnetic mode that “feels” both the core and the cladding. Therefore, the effective index is a weighted average that depends on:
  • The refractive indices of the core and cladding materials.
  • The physical dimensions of the core.
  • The wavelength of the light.
2. Environmental Sensitivity
The effective refractive index is highly sensitive to environmental changes, which is the physical basis for many Fiber Bragg Grating (FBG) sensors produced by OFSCN®.
  • Temperature Sensitivity: As temperature changes, the density and electronic properties of the silica change (the thermo-optic effect), causing n_{eff} to fluctuate. This shift is what allows an OFSCN® FBG Temperature Sensor to measure heat with high precision.
  • Strain/Mechanical Stress: When a fiber is stretched or compressed, the physical density and the geometry of the fiber change (the photo-elastic effect), altering n_{eff}. This principle is utilized in OFSCN® FBG Strain Sensors.
3. Application in FBG Technology
In FBG technology, the reflected wavelength (\lambda_B) is directly determined by the effective refractive index:
(Where \Lambda is the grating period)
Any environmental factor that shifts n_{eff} will cause a shift in the reflected wavelength, which is then measured by an interrogator.
For more information on how these physical properties are utilized in sensing, you can refer to:
OFSCN® Fiber Bragg Grating (FBG) Knowledge Base
