How many years can the text on the label last without peeling off under oil and high temperatures?
The durability of markings on fiber optic patch cord labels in high-temperature and oily environments depends entirely on the substrate of the label, the printing process (inking method), and the physical and chemical stability of the adhesive/fixing structure. Different grades of marking solutions offer durability ranging from “a few months” to “the same lifespan as the patch cord itself (over 10 \sim 20 years)”.
I. Core Physical/Material Factors Determining Marking Durability
- Impact of Oily Environments (Chemical Swelling and Degradation)
- Ink Dissolution: Machine oil, transformer oil, or hydraulic oil are organic solvents. Ordinary dye-based inks or wax/resin ribbon prints can diffuse and dissolve upon contact with oil.
- Adhesive Failure: Conventional acrylic or rubber-based adhesives can swell with prolonged exposure to grease, leading to label curling and detachment.
- Impact of High-Temperature Environments (Thermal Oxidation and Decomposition)
- Substrate Aging: Ordinary PVC or standard PET can become brittle, yellow, and shrink under sustained high temperatures (> 60\ ^\circ\text{C} \sim 80\ ^\circ\text{C}).
- Adhesive Carbonization: High temperatures accelerate adhesive aging, causing it to lose tack or carbonize and peel off.
II. Durability Assessment of Common Marking Solutions
| Marking Type & Process | Temperature Range | Oil Resistance | Expected Lifespan | Typical Application Scenarios |
| Standard Self-Adhesive Labels (Standard PET/PVC + Wax/Resin-Ribbon Print) |
-10\ ^\circ\text{C} \sim 60\ ^\circ\text{C} | Poor (Easily dissolves, bubbles, and peels off with oil contact) | A Few Months to 1 Year | Indoor general weak current equipment rooms, temporary cabling |
| Industrial Grade High-Temperature Heat Shrink Tubing (Cross-linked Polyolefin/PVDF + Resin Ribbon Thermal Transfer) |
-55\ ^\circ\text{C} \sim 125\ ^\circ\text{C} (PVDF up to 150\ ^\circ\text{C}) | Good (Resistant to most industrial lubricants and gasoline) | 5 to 10 Years | Industrial automation, internal cabling in cabinets |
| Industrial Grade Polyimide (PI) High-Temperature & Oil-Resistant Labels (Kapton Substrate + Top-tier Full Resin Ribbon + Chemical-Resistant Acrylic Adhesive) |
-40\ ^\circ\text{C} \sim 200\ ^\circ\text{C} (Short-term resistance to higher temperatures) | Excellent (Resistant to mineral oils, insulating oils, and cleaning solvents) | 8 to 10+ Years | Industrial sensor leads, transformer winding temperature measurement, engine bay interiors |
| Laser Marking / Stainless Steel Metal Plates (Fiber laser cold marking directly on metal armored tubes, metal connector housings, or stainless steel hanging tags) |
-270\ ^\circ\text{C} \sim 700\ ^\circ\text{C} (Depends on the metal material itself) | Excellent (Completely resistant to grease and common chemicals) | 15 to 20+ Years (Permanent, same lifespan as fiber optic patch cord) |
Extreme harsh industrial environments, petrochemical, metallurgical, and high-voltage power equipment |
III. Engineering Testing and Evaluation Standards
Industrial and telecommunications sectors typically employ the following standards to quantitatively assess the durability of fiber optic patch cord or cable markings:
- Abrasion/Solvent Resistance Test (IEC 60794-1-2 Method F12 / GB/T 7424.2): Evaluate legibility by rubbing with a cotton cloth immersed in isopropanol, mineral oil, or specified solvents under a specified load (e.g., 5\ \text{N}) for over 50 reciprocations.
- UL 969 Marking and Labeling System Standard: Provides certification ratings for adhesive strength and legibility of labels after exposure to high-temperature thermal aging, oil immersion, and UV radiation.
IV. Engineering Recommendations
For fiber optic patch cords deployed in harsh engineering conditions with coexisting high temperatures and oily environments (e.g., industrial-grade stainless steel seamless steel pipe armored patch cords produced by Beijing Dacheng Yongsheng Technology Co., Ltd.):
- **Regular Industrial Environments (\\le 120\ ^\circ\text{C}) **: Industrial-grade full resin thermal transfer sleeves or polyimide (PI) oil-resistant labels are recommended.
- Extreme High-Temperature, Oil-Immersed, or Long-Life Service Conditions (> 150\ ^\circ\text{C} or strong corrosion): Laser marking directly on metal structural components or bundling 304/316 stainless steel laser-engraved nameplates is advised, avoiding any organic polymer adhesives.
For more information on the structural and material properties of industrial-grade and high-temperature resistant fiber optic patch cords, please refer to:
OFSCN® Fiber Optic Patch Cord Product Classification Link
