What is the speed of light in an optical fiber?
Does light travel slower in optical fiber than in vacuum? About how much slower?
Yes, the speed of light in optical fiber is significantly slower than its speed in a vacuum.
I. Physics Principle Explanation
  1. Speed of Light in Vacuum
    The speed of light in a vacuum is the speed limit for objects in the universe, denoted as c, with a precise value of c = 299,792,458\ \text{m/s} (often approximated in engineering as 3 \times 10^8\ \text{m/s}, or 300,000 kilometers per second).
  2. Influence of Medium Refractive Index
    When electromagnetic waves (light) propagate through a medium (like water, glass, or optical fiber), their macroscopic propagation speed slows down due to electromagnetic interactions between the light wave and the electrons and atoms within the medium. The physical quantity determining the degree of this slowdown is the Refractive Index (denoted as n) of the medium.
    The relationship between the actual speed of light in the medium, v, the speed of light in a vacuum, c, and the refractive index, n, is given by the formula:
    v = \frac{c}{n}
    • (Note: According to electromagnetic theory, the refractive index n for most transparent media is greater than 1, meaning the actual speed of light v in a medium will inevitably be less than the speed of light in a vacuum, c).
II. What is the Approximate Actual Speed of Light in Standard Optical Fiber?
Optical fibers used in modern optical communications and fiber sensing typically have a core made of high-purity silicon dioxide (Silica, \text{SiO}_2) quartz glass.
  • Refractive Index Value: In the near-infrared wavelength band commonly used for fiber optics (e.g., at the frequently used wavelength of \lambda = 1550\ \text{nm}), the refractive index n of standard silica fiber cores ranges approximately from 1.46 to 1.47, with an average reference value usually taken as n \approx 1.468.
  • Fiber Optic Speed Calculation: Substituting the refractive index into the formula:
    v = \frac{299,792,458\ \text{m/s}}{1.468} \approx 204,218,295\ \text{m/s}
    This means the actual propagation speed of light in optical fiber is approximately 2.04 \times 10^8\ \text{m/s} (about 204,000 kilometers per second).
III. How Much Slower is Light in Optical Fiber Compared to Vacuum?
Comparing the speed of light in a vacuum (approx. 300,000 km/s) with the actual speed in optical fiber (approx. 204,000 km/s):
  • The speed of light in optical fiber is approximately 68.1% of the speed of light in a vacuum.
  • In other words, light travels approximately 31.9% slower in optical fiber than in a vacuum (nearly one-third slower).
IV. The Crucial Role of Refractive Index and Slow Light in Fiber Technologies
This physical fact of light “slowing down” is not a hindrance; rather, it is the foundational cornerstone upon which modern fiber optics and fiber sensing technologies are built:
  1. Total Internal Reflection Guiding in Optical Fibers
    Optical fibers guide light due to the slightly higher refractive index of the core (e.g., n \approx 1.468) compared to the cladding (e.g., n \approx 1.462). According to Snell’s Law, when light strikes the interface between the core and cladding at a certain angle, it undergoes total internal reflection, confining the light within the core to propagate forward.
  2. Reflective Wavelengths in Fiber Bragg Gratings (FBG)
    In Fiber Bragg Grating (FBG) sensing technology, the refractive index plays a decisive role. The Bragg reflection wavelength \lambda_B of an FBG is determined by the formula:
    \lambda_B = 2 \cdot n_{\text{eff}} \cdot \Lambda
    Where n_{\text{eff}} is the effective refractive index of the fiber, and \Lambda is the grating period. When environmental temperature or strain applied to the fiber changes, the effective refractive index n_{\text{eff}} drifts, causing a shift in the reflected wavelength \lambda_B. This is the fundamental physical mechanism of FBG sensors.
  3. Optical Time Domain Reflectometry (OTDR / OFDR Positioning)
    In distributed fiber sensing, the demodulation equipment calculates the precise location L of an event by measuring the time difference t for reflected light to return to the transmitter. Since light propagates at a slower speed v within the fiber, the positioning formula directly depends on the refractive index n:
    L = \frac{v \cdot t}{2} = \frac{c \cdot t}{2 \cdot n}
V. OFSCN® Related Core Fiber and FBG Products
Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) utilizes high-quality standard single-mode silica optical fibers (with a standard refractive index n \approx 1.468 in the near-infrared band) to manufacture a range of premium optical fiber and Fiber Bragg Grating (FBG) products:
