What is the "Thermo-optic Effect"?
Why does the refractive index of a material change with temperature? Is this the fundamental principle behind FBG temperature sensing?
The Thermo-optic Effect refers to the phenomenon where the refractive index (n) of a material changes as its temperature (T) fluctuates. This is indeed one of the two fundamental physical principles behind Fiber Bragg Grating (FBG) temperature sensing.
Why does the refractive index change?
At a microscopic level, the refractive index of a material is determined by its density and the polarizability of its constituent atoms/molecules. When the temperature changes:
  1. Density Changes: As a material expands or contracts (Thermal Expansion), the number of atoms per unit volume changes, affecting how light interacts with the medium.
  2. Electronic Polarizability: For optical fibers (typically silica-based), temperature affects the energy band structure and the vibration of the crystal lattice. This changes the “readiness” of the material’s electrons to respond to the electromagnetic field of the light, thereby altering the refractive index. In silica fibers, the thermo-optic effect is usually the dominant factor, contributing significantly more to the wavelength shift than physical expansion.
Is this the principle behind FBG temperature sensing?
Yes. An FBG sensor works by reflecting a specific wavelength of light, known as the Bragg wavelength (\lambda_B), which is defined by the formula:
Where:
  • n_{eff} is the effective refractive index of the fiber core.
  • \Lambda is the grating period (the physical spacing between the markings).
When the temperature changes, the FBG sensing principle relies on two simultaneous shifts:
  1. Thermo-optic Effect: The refractive index (n_{eff}) changes.
  2. Thermal Expansion: The grating period (\Lambda) physically stretches or shrinks.
Because both n_{eff} and \Lambda change with temperature, the reflected Bragg wavelength (\lambda_B) shifts. By measuring this wavelength shift using an interrogator, we can calculate the precise temperature change.
OFSCN® Product Mapping
In industrial applications, DCYS (OFSCN) utilizes these principles to manufacture high-precision sensors. For instance, our sensors are designed to protect the FBG while ensuring these physical effects are accurately captured:
For more information on how we utilize FBG technology for temperature measurement, you may visit:
Fiber Bragg Grating Temperature Sensors
