How can I find out which worker processed this jumper by scanning the barcode?
In industrial manufacturing and quality management systems (such as ISO 9001, TL 9000, etc.), “Traceability” refers to the ability to track the history, application, or location of a product or component through recorded identification.
The barcode (or QR code / serial number) on a fiber optic patch cord itself typically does not directly record the worker’s name in plain text. It serves as a Unique Identifier (UID / SN), acting as a retrieval key in a database. To find out which specific operator polished the connector end-face of a patch cord, one must rely on the factory’s MES (Manufacturing Execution System) or Routing Traveler records.
The specific implementation and query principles for industrial traceability are as follows:
I. Data Binding Mechanism in Production Site (Forward Recording)
In the standardized process of polishing and manufacturing fiber optic patch cord end-faces, the association of personnel and product data is typically recorded in the system according to the following workflow:
- Unique Identification (UID / SN) Generation
During material cutting or assembly, the patch cord is assigned a unique barcode or batch work order number. - Data Binding of Man, Machine, Material, Method, and Environment (Check-in / Scan)
When entering the end-face polishing process, the operator needs to perform a scan operation at the workstation terminal:- Scan the employee badge barcode (to identify the Operator’s Employee ID);
- Scan the barcode of the polishing machine and fixture (to identify the Equipment and Fixture Number);
- Scan the batch number of the polishing consumables (to identify the grit and batch of the polishing sandpaper);
- Scan the barcode on the fiber optic patch cord (or its carrier tray) (to identify the Work-in-Progress SN).
- Data Solidification and Timestamp
After the process is completed and end-face quality inspection is performed (e.g., checking parameters like curvature radius, apex offset, and fiber height using a fiber connector interferometer), the system automatically solidifies the polishing parameters, pass/fail inspection reports, operator ID, and completion time into the factory’s MES database.
II. Query Steps to Trace the Polishing Worker via Barcode (Reverse Traceability)
If you need to trace the polishing worker based on the barcode on the patch cord, the specific path is as follows:
- Read Barcode Data
Use a barcode scanner or scanning device to read the barcode on the fiber optic patch cord label and obtain its original encoded string (i.e., the product SN or work order traveler number). - Access Production Manufacturing Execution Database (MES / ERP)
Input this string into the traceability module of the production manufacturer’s internal MES system.
Note: This database is part of the enterprise’s internal industrial system. For data security and privacy reasons, it is typically only accessible by internal factory quality management (QA/QC), engineering, or after-sales technical departments and is not publicly available on the internet. - Retrieve Process History / Audit Trail
Within the product lifecycle history tree of the system, locate the specific step of “Polishing Process”. - Parse Process Attributes
The system interface will display the complete metadata for this process step:- Work Order
- Station / Machine ID
- Operator ID & Name
- Timestamp of Polishing Completion
- Corresponding Process Step End-face Inspection (Interferometer Data) and Inspector Information
III. Notes in Practical Engineering
- Single-piece Traceability vs. Batch Traceability
- High Reliability / Industrial Grade / Custom Fiber Optic Patch Cords: Typically implement Single-piece Tracking, where each patch cord corresponds to an independent SN, allowing precise traceability to the polishing personnel and test curves for each end-face of a single patch cord.
- General Consumer Grade / Bulk Communication Fiber Optic Patch Cords: Some factories may adopt Batch Tracking. In this case, the barcode corresponds to a batch of work orders (e.g., 50 or 100 pieces), and the query result usually indicates the corresponding machine group or shift operators scheduled for polishing for that batch.
- External User Query Method
Since production process data is stored in the original manufacturer’s internal system, if a customer purchases finished patch cords and needs to attribute quality incidents or conduct audits, they cannot directly obtain worker information through third-party general scanning software. They must provide the barcode serial number on the patch cord to the production manufacturer’s Quality Assurance Department. The original manufacturer’s technical personnel will then export a “Traceability Report” from the internal database.
