Why can't standard patch cords withstand heavy pressure?
If an office chair wheel rolls over a patch cord, will the signal be interrupted?
In most cases, yes, a standard office chair wheel rolling over a standard fiber optic patch cord will cause a signal interruption or even permanent physical damage.
From a technical perspective, there are two primary reasons why standard patch cords fail under heavy pressure:
1. Macro-bending and Micro-bending Loss
Standard patch cords typically use a 2.0mm or 3.0mm PVC/LSZH outer jacket with aramid yarn (Kevlar) for tensile strength. However, these materials provide almost zero structural resistance to lateral compression (crushing).
When an office chair wheel—which concentrates significant weight onto a very small contact area—rolls over the cord, the glass fiber inside is deformed. This creates macro-bending or micro-bending, causing the light signal to leak out of the core and into the cladding, leading to immediate signal attenuation or a complete “link down” event.
2. Physical Fracture of the Glass Core
Standard optical fibers have a diameter of 125 microns (about the thickness of a human hair). Without a rigid protective layer, the concentrated pressure from a chair wheel can exceed the structural limit of the glass, causing it to crack or shatter.
The Solution: Armored and Reinforced Cables
If your environment involves potential crushing hazards (like wheels, foot traffic, or heavy equipment), standard patch cords are insufficient. OFSCN® specializes in specialized structural designs to solve this:
  • OFSCN® Stainless Steel Tube Armored Fiber Optic Cables: These incorporate a micro-diameter stainless steel hose. The metal structure absorbs the lateral pressure, ensuring the fiber inside remains unstressed even if stepped on or rolled over.
  • OFSCN® Seamless Steel Tube Fiber Optic Cables: For extreme industrial environments, these provide maximum crush resistance and can withstand significantly higher mechanical loads than standard commercial cables.
Related Products:
If you are designing a sensing or communication link for a high-traffic area, I recommend selecting a cable with a metal reinforcement layer.
