Can this jumper wire be strung between two poles like an electrical wire?
Yes, but whether it can be suspended between two poles like an electric wire depends on the specific product structural design, span (clearance), and installation stress fixing method.
From the perspective of engineering physics and optical cable structural design, the relevant technical points and specifications are as follows:
1. Engineering Physics Principle of “Self-supporting”
“Self-supporting” refers to an optical cable or drop wire that, by design, incorporates a high-strength reinforcing member (such as steel wire, stranded steel wire rope, non-metallic FRP, or aramid yarn) capable of withstanding its own weight and environmental loads (like wind load, ice accumulation). This allows it to be suspended independently without the need for an additional messenger wire.
2. Key Engineering Conditions for Aerial Suspension
When suspending self-supporting drop wires/optical cables between two poles, the following three engineering specifications must be met:
Span (Clearance) Matching with Tensile Strength:
- Short to Medium Spans (typically 10\ \text{m} to 50\ \text{m}): Self-supporting drop wires/patch cords with reinforcing steel wires or steel wire ropes have sufficient mechanical strength for short-distance suspension and are often used for aerial installation in the last mile or for indoor/outdoor bridging across walls/short pole routes.
- Long Spans (> 50\ \text{m}): Heavy-duty aerial optical cables (such as ADSS all-dielectric self-supporting optical cables or large-section steel wire self-supporting optical cables) are required. Lightweight patch cords, even with steel wires, cannot withstand the tension and wind-induced vibration caused by the sag in long spans.
Stress Stripping Principle (Absolutely Prohibit Pulling Connectors):
- The optical fiber connectors (FC, SC, LC, etc.) at both ends of the fiber optic patch cord cannot bear any tensile force.
- During aerial fixation, the tension must be completely stripped and concentrated on the self-supporting reinforcing steel wire/steel wire rope. Use dedicated tension clamps or hooks to fix it to the pole. It is strictly forbidden to transfer the tensile force to the optical fiber connector or the cable exit.
Environmental Resistance Requirements:
- Outdoor aerial environments require resistance to ultraviolet (UV) radiation, anti-aging capabilities, and a wide operating temperature range to prevent cracking of the outer sheath, which could lead to moisture ingress or corrosion of the steel wires.
3. OFSCN® Official High Tensile Strength / Steel Wire Rope Reinforced Patch Cord Products
For applications requiring extremely high mechanical tensile strength and suspension in harsh industrial/outdoor environments, Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) offers reinforced fiber optic patch cords with double protection from steel wire rope and seamless steel tubes:
- OFSCN® 3.0mm Steel Wire Rope Fiber Optic Patch Cord
Composed of fiber optic connectors, PE sheath, a 0.45\ \text{mm} stainless steel wire stranded structure, a 0.9\ \text{mm} stainless steel seamless steel tube, and optical fibers. Its tensile strength reaches > 1200\ \text{N}, compressive strength > 200\ \text{MPa}, and operating temperature range is -40\ ^\circ\text{C} to 75\ ^\circ\text{C}.
- OFSCN® 2.0mm Steel Wire Rope Fiber Optic Patch Cord
Composed of fiber optic connectors, a 0.6\ \text{mm} galvanized steel wire stranded structure, a 1.0\ \text{mm} stainless steel seamless steel tube, and optical fibers, forming an all-metal structure. Its tensile strength can reach > 1500\ \text{N}, compressive strength > 150\ \text{MPa}, and operating temperature range is -40\ ^\circ\text{C} to 85\ ^\circ\text{C}.
Summary Recommendation
For pole-to-pole bridging over short to medium distances, using self-supporting patch cords with steel wire reinforcement and ensuring proper fixation of the steel wire tension at both ends is entirely feasible. For long-distance installations on utility poles, it is advisable to evaluate the tension and sag and select engineering-grade heavy-duty aerial optical cables.
