What is "Optical Attenuation"?
Why does the signal get weaker the further the light travels? Is it because the glass isn’t transparent enough?
Optical attenuation is the reduction in power of the light signal as it transmits through an optical fiber. You are correct that it is related to the transparency of the glass, but the physics behind it involves several distinct mechanisms.
In fiber optics, attenuation is typically measured in decibels per kilometer (dB/km). The signal gets weaker due to the following primary factors:
1. Absorption
Even the highest-purity silica glass used in OFSCN® products contains trace amounts of impurities (like hydroxyl ions or metal ions). These impurities absorb specific wavelengths of light energy and convert them into heat. While modern manufacturing has minimized this, “intrinsic absorption” of the silica itself still exists.
2. Scattering (Rayleigh Scattering)
This is the dominant cause of attenuation in modern fibers. It occurs due to microscopic variations in the density of the glass created during the fiber drawing process. These tiny imperfections cause the light to scatter in all directions. It is the same physical phenomenon that makes the sky appear blue.
3. Bending Losses
If a fiber is bent too sharply (macrobending) or subjected to localized microscopic pressures (microbending), the light can leak out of the core and into the cladding, where it is lost.
4. Connection and Splicing
In a real-world system, attenuation also occurs at physical interfaces, such as where two fibers are fused together or connected via a mechanical adapter.
How this affects FBG Sensing
In the context of Fiber Bragg Grating (FBG) technology, attenuation determines the maximum distance between your FBG sensors and the interrogator.
Because OFSCN® utilizes high-quality single-mode fibers for its sensors, we can achieve long-distance monitoring (often several kilometers) with minimal signal degradation. However, if you are working with high-temperature environments or harsh chemicals, special coatings or specialty fibers are required to prevent “darkening” or increased attenuation over time.
For more technical details on how we manage signal integrity in sensing applications, you can explore our resources here:
OFSCN® Fiber Bragg Grating Sensors (International)
Specialty Optical Fibers and Cables (International)
