Why is every demodulator measured with a “standard ruler” before leaving the factory?
In fiber optics and optical measurement engineering, the act of measuring with a “standard ruler” is professionally referred to as Wavelength Calibration and Wavelength Traceability.
An optical fiber Bragg grating (FBG) interrogator is essentially an ultra-high-resolution optical spectrum analysis device. The core physical quantity it demodulates is the characteristic wavelength \lambda (typically precise to picometers, \text{pm}, i.e., 10^{-12}\ \text{m}) of the reflected or transmitted light from the fiber Bragg grating. Before leaving the factory, interrogators must undergo rigorous wavelength calibration. The physical principles and engineering necessity of this process are primarily reflected in the following aspects:
I. What is “Wavelength Calibration”?
The interrogator’s internal optoelectronic hardware system (such as the piezoelectric actuation scan of a swept-source laser, the pixel indexing of a spectrometer’s array detector, or the driving voltage of a tunable Fabry-Pérot filter) acquires raw electrical signals that are non-wavelength physical quantities (e.g., scan driving voltage, sample point index, detector pixel position, or timestamp).
Wavelength Calibration is the process of using known, constant, and immutable physical standard reference sources (i.e., optical “standard rulers”) to establish an absolute mathematical mapping function between the discrete signals acquired by the interrogator’s internal system and the international standard vacuum/air wavelengths:
Here, x represents the driving voltage, time index, or detector physical channel, and f(x) is typically a high-order polynomial correction function fitted by a calibration algorithm.
II. Why Must Measurement with a “Standard Ruler” Be Performed Before Factory Release?
1. Eliminating Intrinsic Limitations and Discrete Errors of Optical Components
Whether based on tunable laser sweeping or dispersive spectroscopy principles, the system exhibits non-ideal physical characteristics:
- Non-linearity of Actuators and Crystals: The piezoelectric actuators (PZT) within swept-source devices inherently possess hysteresis, creep, and non-linear driving responses.
- Non-linear Dispersion of Dispersive Elements: In spectrometer systems, the dispersion angle of diffraction gratings or prisms does not vary linearly with wavelength in an ideal manner.
Without multi-point grid calibration of the entire tuning curve using standard wavelengths before factory release, the spectral wavelengths directly calculated by the interrogator will suffer from severe local distortions and global wavelength drifts.
2. Ensuring Absolute Wavelength Accuracy and Equipment Interchangeability
In fiber sensing applications, parameters such as temperature, strain, stress, or displacement are converted from wavelength shifts \Delta \lambda:
- If there is an initial deviation in the absolute wavelength between multiple interrogators, replacing the interrogator host in the field or paralleling multiple devices in the same project will result in baseline drift in the measured values of the same sensor.
- Interrogators must achieve absolute accuracy and repeatability at the picometer level (e.g., 1\ \text{pm} or 0.1\ \text{pm}) to ensure the reliability of physical measurement data.
3. Traceability to International Spectral Standards
The
