Why shouldn't standard patch cords be subjected to heavy loads or crushing?
Will the signal be interrupted if the office chair wheels roll over a jumper wire?
If an office chair’s wheels run over a standard fiber optic patch cord, the signal is highly likely to experience instantaneous interruption, packet loss, or even cause permanent breakage of the fiber, leading to a complete and unrecoverable loss of signal.
We can analyze the mechanism from two perspectives: optical physics and mechanical engineering structure:
I. Analysis of Physical Mechanism: Why Standard Patch Cords Can’t Withstand Chair Wheel Pressure?
Ordinary indoor fiber optic patch cords (such as common PVC jacketed cables) have a very fragile internal structure. They typically consist of only a silica glass fiber with a diameter of 125\ \mu\text{m} ( 250\ \mu\text{m} with coating or 0.9\text{mm} after tight buffer), a small amount of aramid (Kevlar) for tensile strength, and a thin PVC sheath.
When an office chair wheel with someone sitting on it rolls over the patch cord, the following physical effects occur:
  1. Instantaneous Signal Interruption: Macrobending & Microbending Loss
    When an office chair wheel contacts the floor (especially hard surfaces like tiles or concrete), the contact area A is extremely small. According to the pressure formula:
    \text{Pressure } P = \frac{F}{A}
    Even with a combined weight of only 70\text{kg} (approximately 700\text{N}) from the person and chair, the local pressure generated at the edge of the wheel is immense. The standard PVC sheath deforms severely and instantaneously, transmitting this pressure directly to the internal glass fiber, causing microscopic and macroscopic severe bending of the fiber.
    This bending disrupts the physical conditions for total internal reflection (TIR) of light within the fiber core, leading to significant light signal leakage (loss typically spikes instantaneously to \gt 10\text{dB} or even higher). This causes the optical power received by the optical receiver module to fall below its sensitivity threshold, resulting in instantaneous disconnection or severe packet loss.
  2. Permanent Signal Interruption: Brittle Fracture of Glass Fiber
    Silica glass is a typical brittle material. When the shear forces and localized high pressure generated by the chair wheel’s rolling exceed the glass’s ultimate compressive and bending strength, micro-cracks form within the fiber, or it may even fracture (break) directly. Once the fiber experiences physical breakage, the optical signal cannot pass through, causing permanent signal interruption, and the patch cord must be discarded and replaced.
II. Solution: Industrial-Grade, Pressure-Resistant Armored Fiber Optic Patch Cords
To address complex mechanical challenges such as heavy object rolling, foot traffic, and chair wheels in office environments, laboratories, server rooms, or industrial sites, it is essential to use pressure-resistant armored fiber optic patch cords with a metal protective layer.
Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) offers a series of armored fiber optic patch cords with built-in stainless steel seamless steel tube protection, designed for these harsh force-bearing environments. These patch cords possess extremely high pressure and tensile resistance, ensuring zero signal loss even when repeatedly run over by chair wheels, keeping the internal fiber in a “zero-stress” state.
1. OFSCN® 2.0mm Micro Steel Armored Fiber Optic Patch Cord | Official Link
This product, with an ultra-thin outer diameter of only 2.0\text{mm}, integrates a 0.6\text{mm} stainless steel seamless steel tube. It provides robust rigid protection while maintaining excellent flexibility.
  • Physical Performance: Tensile strength \gt 150\text{N}, compressive strength \gt 240\text{MPa}.
  • Structural Features: The stainless steel seamless steel tube perfectly shields the glass fiber from external squeezing by chair wheels, eliminating microbending and fiber breakage risks.
  • Product Images:
2. OFSCN® 3.0mm Steel Wire Rope Fiber Optic Patch Cord | Official Link
This patch cord is specifically designed for heavy-load, high-tension, and extreme pressure environments, employing a dual metal protection structure.
  • Structure: Consists of fiber connector, PE sheath, a 0.45\text{mm} stranded steel wire structure, a 0.9\text{mm} stainless steel seamless steel tube, and the fiber.
  • Physical Performance: Tensile strength \gt 1200\text{N}, compressive strength \gt 200\text{MPa}.
  • Product Images:
3. OFSCN® 2.0mm Steel Wire Rope Fiber Optic Patch Cord | Official Link
  • Structure: Full metal structure, consisting of fiber connector, a 0.6\text{mm} galvanized steel wire stranded structure, a 1.0\text{mm} stainless steel seamless steel tube, and the fiber.
  • Product Images:
For more information on stainless steel seamless steel tube armored patch cords and fiber optic cables for different environments and temperature zones, you can visit OFSCN® Fiber Optic Patch Cord Product Classification | Official Link for academic and engineering technical parameter comparisons.
